Replacing axle shaft
Transmission, Clutch, Torque Converter, Rear End, Axles, Driveshafts
PostPosted: Thu Aug 31, 2017 12:21 pm
One of the boots on the driver side axle shaft is torn and flinging grease so I need to replace the axle shaft. Found a great video on YouTube for replacing them. However, there is a spring washer and spacer behind the hub that the guy in the video said is a 1 time use. I cannot find a new one online anywhere. I do not know the part number or the "official" name of it. Anyone know what the name of the part is or better yet, the part number?
I suppose I could just try reusing the one on there, but I plan on keeping the car for a long time so I want to do it right.
Gordy
Injen CAI / VMax TB / SOLO Hi-flow res-cats & Mach X-LLT / Pedders Street I / SS Struts / Pfadt drop springs / Spohn Toe Rods & Trailing Arms
Black bow ties & trunk panel / Fogs / Footwell lighting front & rear / 35% Tint
PostPosted: Thu Aug 31, 2017 9:27 pm
Does this help?
https://www.gmpartsdirect.co/oem-parts/ ... Ni1nYXM%3D
PostPosted: Fri Sep 01, 2017 12:53 pm
Not really. I need a diagram for our IRS.
Gordy
PostPosted: Mon Sep 04, 2017 4:47 pm
Didn't even catch that. I am not sure what I was thinking. I should know better that this is not our back end, but that is what came up in the GM site........DUH.
Try this instead.
https://gmemployeepartsdiscount.com/par ... am=CD10595
I see the washer in the picture below, but no part number, still searching for you.
PostPosted: Tue Sep 05, 2017 12:33 pm
Yes, that's the washer. My new axle did not include one.
Gordy
PostPosted: Tue Sep 05, 2017 3:13 pm
Thanks for posting that pic. Put it on a facebook group and got part number 11611965.
EDITED TO ADD: Apparently, that is the part number for V8 & V6 manual only. V6 auto has different axle shafts. I have the manual, so I'm set.
Gordy
PostPosted: Tue Sep 05, 2017 8:16 pm
Good to hear you are good to go.
Return to Transmission and Drivetrain
