Timing chain solution?
Heads, Cams, Valvetrain, Bottom End
PostPosted: Mon Jan 31, 2011 9:17 pm
Mobile 1. If you guys want some really cool info on oil, and other fluids go to: http://www.bobistheoilguy.com
PostPosted: Thu Feb 03, 2011 3:28 am
I'm running castrol edge in my car changing my oil about every 4500 miles and it hasn't given me any problems, and my car was produced with the old timing chain.
PostPosted: Thu Feb 03, 2011 4:45 am
i am also using castrol with k&n oil filter. oil change after 500 miles and now every 3000-3500 miles. no problems with the timing chain (9500 miles)
ohio-speed.com is your #1 place for high performance parts & show car accessories
PostPosted: Thu Feb 03, 2011 7:50 am
Timing chain issue seems to pop up around 30,000 to 40,000 miles... Our 2009 Acadia had it's chains replaced at 32,000 miles... I had 38,000 on the Camaro when I traded it in and no chain issue..
PostPosted: Thu Feb 03, 2011 11:27 am
I'm pushing 30k, and no issues. I do have an oil change coming up, I'll chat with my tech and see what he has to say.
Image1LT/RS RY; Trifecta tuned, Injen long tube CAI, ARH long tubes/cats,custom catback with Flowmaster Super 44s, IAT relocate and RXtreme catch can/breather
PostPosted: Thu Feb 03, 2011 1:17 pm
This cannot be stressed enough, so I will repeat my post again.
Posted: Fri Jan 14, 2011 1:54 pm
Change the oil at 5000 miles or sooner and you should be safe. The trouble starts when you go towards the end of the 100% indicator.
PostPosted: Fri Feb 04, 2011 12:38 pm
rtcat600man wrote:This cannot be stressed enough, so I will repeat my post again.
:werd: At the dealer today and I asked the service manager if they had to replace any chains on the 3.6. Yes indeed on 2 Traverse's but he stressed it was because the owners were negligent on changing their oil.
He said I should have no problems if the oil is changed regularly.
GMPP exhaust/JBA shorties/Vararam CAI/VMax TB/SLP Pulley/Hypertech programmer/VMax Isolater/Mace Ported IM & Plenum Spacer
PostPosted: Fri Feb 04, 2011 1:43 pm
EXACTLY...........good to hear...... :thumbsup:
PostPosted: Fri Feb 04, 2011 5:15 pm
cool cause i don't want my car needing a new engine after just 40k miles. i change my oil every 3k to 4.5k miles so i shouldn't have to worry about this problem. here's the real question with modifications installed does it create more stress on the timing chain or not?
PostPosted: Fri Feb 04, 2011 5:25 pm
a red maro wrote:cool cause i don't want my car needing a new engine after just 40k miles. i change my oil every 3k to 4.5k miles so i shouldn't have to worry about this problem. here's the real question with modifications installed does it create more stress on the timing chain or not?
Actually they were able to do the Acadia's timing chains in like a day or so... no new engine. Don't think mods are really going to add that much stress unless you go FI... Worst thing for them appears to be dirty oil... I changed my oil well before the DIC told me too!
Now the question will be will your dealership try to blame your mods on your chain issues (if you had one)? That's always the tough question...
Return to 2010-2011 LLT 3.6l Internal Engine Tech
