Custom air duct
PostPosted: Sat Jul 04, 2015 12:03 am
Does anyone have any ideas about a custom air duct coming from the bottom grill ? Suggestions on plastic or aluminum. And has anyone ever did this or attempted to do this ?? Thanks guys.
Sent from my SAMSUNG-SM-G925A using Tapatalk
PostPosted: Mon Jul 06, 2015 6:06 am
Injen makes a system that draws the air from down low, only issue is you need to be careful you don't drive thru a water hole that is deep enough to suck water up thru the tube. You would need to drive thru at least a foot deep water hole to have an issue. Also, I cut part of the back side of the grill away to allow even more air to get to the filter area, similar to what the APEX system does in directing air to the bottom of the CAI systems.
