LLT coolant temp sensor location ?
PostPosted: Tue Oct 22, 2013 9:00 am
Where is the coolant temp sensor located ? It is usually found where the coolant hose enters the block. Can't find it ???
PostPosted: Tue Oct 22, 2013 10:24 am
hope this helps
PostPosted: Tue Oct 22, 2013 7:02 pm
Thanks ! This helps a lot. Trying to trouble shoot misfires on Cold start mode. Going to disconnect the sensor since the ecu uses this sensor for fuel and timing during this mode. I am hoping to isolate the problem.
PostPosted: Tue Oct 22, 2013 7:49 pm
:thumbsup:
