Check engine light with K&N Typhoon CAI
Bolt-Ons, Intakes, Exhaust, Ignition, Pulleys
Moderator: mrray13
PostPosted: Thu Jun 20, 2013 12:24 pm
Just intalled a K&N Typhoon CAI on my 2010 LS Camaro (46k miles) and after running for about a week my check engine light has come on. No other modifications, no tune (yet). Any ideas or is this because of the CAI?
2010 ABM Camaro LS.
Site Admin
PostPosted: Thu Jun 20, 2013 1:54 pm
swing by an autozone and have them scan it for free or have a friend who has a scanner check the code. Could be the intake, or could be coincidence that it happened after the install but it is something else. Check the code and let us know, then we can help you out some more. :)
Hi my name is Travis and I have an addiction, an addiction to anything and everything dealing with v6 camaros. :wave:
****T.O.P. SNIPER****
PostPosted: Thu Jun 20, 2013 5:55 pm
I have heard that the k&n throws a cel on these cars
PostPosted: Thu Jun 20, 2013 9:49 pm
Yes, I have heard the CEL caused by the K&N is because the filter is too small which actually restricts the amount of air to the engine.
Gordy
Injen CAI / VMax TB / SOLO Hi-flow res-cats & Mach X-LLT / Pedders Street I / SS Struts / Pfadt drop springs / Spohn Toe Rods & Trailing Arms
Black bow ties & trunk panel / Fogs / Footwell lighting front & rear / 35% Tint
PostPosted: Fri Jun 21, 2013 7:11 am
Went by auto zone and the code read. P0449- evaporative emission system. They suggested that the gas cap wasn't on tight but it was/is. Any assistance would be greatly appreciated.
2010 ABM Camaro LS.
Site Admin
PostPosted: Fri Jun 21, 2013 9:29 am
did they clear it to see if the light returns for you? May have to smoke test one of the lines and see if there is a leak somewhere
PostPosted: Mon Jun 24, 2013 9:24 am
Had the code cleared and it came back on after a few minutes of driving.
2010 ABM Camaro LS.
Site Admin
PostPosted: Mon Jun 24, 2013 10:18 am
gonna have to smoke test the system and see if there is a vac line or fuel vapor line leaking somewhere. Could also be a stuck emissions valve as well
Running 12s
PostPosted: Mon Jun 24, 2013 11:36 am
And check the evap connection on the passenger side of the IM about 1/2 way back to make sure nothing is loose. K&N should not cause the evap code......
PostPosted: Tue Oct 08, 2013 6:12 pm
I HAVE HEARD THE KN THROWS CODES AS WELL. WHICH IS Y I WAS HESITANT ON GETTING ONE. HOWEVER ON THE 12 AND UPS I HAVE HERD GREAT THINGS. NO CODES AT ALL.HMMMMM. IT WAS ALSO THE 63 SERIES NOT THE 69 SERIES WHICH HAD THE PROBLEM FAR AS I KNOW.
DONT SLEEP ON THE V6 CAMARO.......ALL HATERS BEWARE!!!
Return to 2010-2011 LLT 3.6l External Engine Tech
