Injen Cold Air Intake
PostPosted: Tue Jan 22, 2013 4:14 am
At what rpms do you get the gains of the Injen long tube cold air intake?
When you turn your Camaro on, does it return the favor? Mine does
PostPosted: Tue Jan 22, 2013 7:02 am
All of them.
PostPosted: Tue Jan 22, 2013 1:02 pm
But where is the peak at? Will I need a tune?
Will it throw me check engine signals?
PostPosted: Tue Jan 22, 2013 1:04 pm
No, you will not need a tune. The Camaro will compensate for the Injen. No CEL's with just a CAI install.
PostPosted: Tue Jan 22, 2013 1:08 pm
Does battery need to be disconnected before removing the stock one?
PostPosted: Tue Jan 22, 2013 1:35 pm
I did
MRT V1/ Injen CAI/ VMax TB/ RX Catch Can/ TrifectaImage
PostPosted: Tue Jan 22, 2013 1:49 pm
It is recomended to disconnect the battery.
PostPosted: Tue Jan 22, 2013 1:56 pm
I heard that doing this makes your car have to relearn everything. Making it not run as good. Is this true?
PostPosted: Tue Jan 22, 2013 2:12 pm
Trentin24 wrote:I heard that doing this makes your car have to relearn everything. Making it not run as good. Is this true?
Actually this is what you want it to do. So that it does relearn with the new intake. After it completes the relearn it will run at its best.
Also, here is the dyno sheet of the test that Jannetty performed 2 years ago when testing 4 differant systems on the same day.
PostPosted: Fri Jan 25, 2013 1:55 am
Did your gas mileage increase?
