How to Replace the Waterpump on 2010 Camaro 3.6l
Planning on doing a project and want to document it for the rest of us? Post it here!
Moderator: mrray13
Site Admin
PostPosted: Tue Feb 22, 2011 10:54 am
Thanks goes out to alldata for the walkthrough on this.
2010 Camaro 3.6l Water Pump Replacement
Removal Procedure
1. Remove the air cleaner resonator and outlet duct assembly.
2. Drain the cooling system.
3. Remove the drive belt tensioner.
4. Remove the drive belt idler pulley.
5. Disconnect the radiator inlet hose from the water pump.
6. Disconnect the radiator outlet hose from the water pump.
7. Disconnect the heater inlet and outlet hose from the water pump.
8. Remove the water pump to block bolts (1).
Note: Always clean the water pump and engine block mating surfaces and discard the gaskets.
9. Remove the water pump (2).
Installation Procedure
Note: Always install a NEW water pump gasket.
1. Install the water pump (2) to the engine block and tighten the bolts (1) to 30 Nm (22 lb ft) .
2. Connect the heater inlet and outlet hose to the water pump.
3. Connect the radiator outlet hose to the water pump.
4. Connect the radiator inlet hose to the water pump.
5. Install the drive belt idler pulley.
6. Install the drive belt tensioner.
7. Fill the cooling system.
8. Install the air cleaner assembly.
Approximately a 50-60 minute job
Hi my name is Travis and I have an addiction, an addiction to anything and everything dealing with v6 camaros. :wave:
****T.O.P. SNIPER****
PostPosted: Tue Feb 22, 2011 11:10 am
Pretty soon you will have the entire Camaro listed here and how to replace anything and everything.
Thank - you for doing all of these threads.
Site Admin
PostPosted: Tue Feb 22, 2011 11:11 am
that's my goal, once the warranties run out, people will be scratching their heads to figure out how things go, and I am just trying to help relieve those headaches. :D
Return to How-To: Article
