Replacing the High Pressure Fuel Pump 2010 Camaro v6 3.6l
PostPosted: Thu May 26, 2011 9:54 am
Special Tools Needed
EN-48896 HP Fuel Pump Installation Alignment Gauge
Removal Procedure
Relieve the low and high side fuel system pressure.
Remove the cross vehicle brace.
Remove the high pressure fuel pump shield.
Remove the intake manifold.
Remove the wiper module.
Disconnect the engine wiring harness electrical connector from the high pressure fuel pump.
Remove the radiator surge tank outlet pipe.
Remove the low pressure feed pipe.
Remove the high pressure pipe. Discard this pipe.
Remove and discard the high pressure fuel pump bolts (4).
Remove the high pressure fuel pump (3).
Remove and discard the high pressure fuel pump gasket (2).
Remove and discard the high pressure fuel pump O-ring.
Remove the high pressure fuel pump roller lifter.
Installation Procedure
Note: The camshaft must be in the base circle position before the high pressure fuel pump is installed.
Use the EN-48896 to ensure that the camshaft lobe is in the base circle position. At base circle the tool will be flush with the head.
Lubricate the high pressure fuel pump cylinder head bore and roller lifter with camshaft prelube GM P/N 12345501 (Canadian P/N 992704) or equivalent.
Install high pressure fuel pump roller lifter.
Install a NEW high pressure fuel pump O-ring.
Note: The high pressure fuel pump gasket has a retaining feature to hold the pump retaining bolts in place.
Position the NEW high pressure fuel pump gasket (2) and bolts (4) to the fuel pump.
Install the high pressure fuel pump (3) to the cylinder head (1). Force will be required while hand tightening the bolts.
Tighten the high pressure fuel pump retaining bolts to 15 Nm (11 lb ft) .
Ensure the high pressure fuel pump and fuel rail fittings are clean prior to assembly.
Install a NEW high pressure fuel pipe.
Install the fuel feed pipe to the high pressure fuel pump.
Connect the high pressure fuel pump wiring harness.
Install the radiator surge tank outlet pipe.
Install the fuel tank cap.
Note: If a fuel leak accrues at the fuel rail, the fuel rail will need to be replaced.
Inspect for leaks using the following procedure:
Turn ON the ignition, with the engine OFF for 2 seconds.
Turn OFF the ignition, for 10 seconds.
Turn ON the ignition, with the engine OFF.
Inspect for fuel leaks.
Install the pressure relief cap to the fuel feed pipe.
Install the wiper module.
Install the intake manifold.
Install the high pressure fuel pump shield.
Install the cross vehicle brace.
PostPosted: Thu May 26, 2011 10:08 am
Thanks Travis. I was just reading this section online and was thinking we needed this posted. Good find and thanks for posting.
PostPosted: Thu May 26, 2011 10:13 am
working on some fuel info to help those with the turbos and the fuel issues. Hopefully we can figure out a way to handle any amount of power :)
PostPosted: Thu May 26, 2011 10:23 am
Thanks Travis! And with Vince working on a E85 tune, this may help them, too.
EFR Twin Turbo LFX-GPI Tune-ZL1 fuel pump-10:1 CR forged pistons-3.45 gear-Meth Injection-BMR Trailing Arms, Bushings & Sway Bars-CircleD 4000 Stall, GPI Fuel Enrichment System
586 RWHP & 606 RWTQ on 93 Octane @20 psi
PostPosted: Thu May 26, 2011 2:33 pm
Excellent Travis!!!!!!!
PostPosted: Tue May 31, 2011 8:50 am
Hey Travis, do your excellent sources have the part number for the HP fuel pump? I'm wondering if the kit they put in the Cobalts will work for us.
PostPosted: Tue May 31, 2011 9:12 am
GretchenGotGrowl wrote:Hey Travis, do your excellent sources have the part number for the HP fuel pump? I'm wondering if the kit they put in the Cobalts will work for us.
hmm, I will do some digging. What year/engine cobalts, all have the same?
PostPosted: Tue May 31, 2011 10:00 am
Don't know. I've got a friend who has a kit for his HP pump (Mazda Speed 3) and he told me last night that the same company does a kit for the Cobalts. He's supposed to send me contact information and I was going to send them our part number to see if they could tell if one of thier kits would work.
PostPosted: Tue May 31, 2011 10:07 am
Found out the part # for the HP fuel pump. Had to call Berger to get it, now to check what cobalts have.
2010 Camaro 3.6l V6 High Pressure Fuel Pump
GM Part # 12626234
List $466.00
PostPosted: Tue May 31, 2011 4:39 pm
any luck getting the contact info? I scanned a few threads on a cobalt thread but didn't come across anything yet
