Wilwood 570 brake fluid?
PostPosted: Sun Apr 03, 2011 9:04 pm
Is it OK to use Wilwood 570 brake fluid in a daily driver?
Gordy
Injen CAI / VMax TB / SOLO Hi-flow res-cats & Mach X-LLT / Pedders Street I / SS Struts / Pfadt drop springs / Spohn Toe Rods & Trailing Arms
Black bow ties & trunk panel / Fogs / Footwell lighting front & rear / 35% Tint
PostPosted: Mon Apr 04, 2011 3:20 am
I wouldn't see why not, however, the question is why are you thinking of switching? I would do some further research. That is used primarily for racing to prevent boiling of the brake fluid.
PostPosted: Mon Apr 04, 2011 9:27 am
what are the specs on it? are you having an issue with your current fluid? You shouldn't be for normal use and some strip runs
PostPosted: Mon Apr 04, 2011 9:29 am
I plan on doing some road-course track days and maybe some autocross events (along with some spirited twisty roads).
Gordy
PostPosted: Thu Apr 07, 2011 3:47 am
My brother works at Wilwood Engeniering.... Is cool because is the only factory at all in the states.... Here in Camarillo CA.... To bad the big brake kits are only for the SS!!
