Replacing a window motor on a 2010 Camaro 3.6l
General problems, repairs and maintenance. Fix squeaks, rattles, etc
Moderator: mrray13
Site Admin
PostPosted: Tue Feb 22, 2011 11:38 am
Door Panel Removal
Window Motor Removal
Window Regulator Motor Programming and Setup
Window Motor Normalized Procedure
A window motor that has not been normalized will no longer perform the express up and express down functions, this may occur during the following conditions:
* When a window motor has been disconnected
* When a door harness has been disconnected
* When the battery has been disconnected or replaced
Note: When DTC B3205 4B & 3210 4B are set, the following warnings will be displayed on the driver information center:
Open, then Close Driver Window
Open, then Close Passenger Window
These warnings will clear once the windows have been "Normalized" and the respective DTC will clear.
To normalize the window motor, follow these steps:
Note: The doors must be completely closed prior to normalizing the windows, a door that is open or ajar may cause the power window to function abnormally or to become inoperative while performing the normalizing procedure. If this occurs, verify that the door is completely closed then repeat the normalizing procedure.
1. Ignition ON.
2. Starting with the window completely UP, press and hold the power window switch until the window is fully open and continue holding the switch down for approximately 5 seconds after the window is completely open.
3. Pull the power window switch up until the window is fully closed and continue holding the switch up for approximately 5 seconds after the window is completely closed.
The window should now be normalized and the window should perform the express up and express down functions.
Window Motor Relearn Procedure
A relearn procedure may need to be performed for any Local Interconnect Network (LIN) window motor for the following conditions:
* When the window glass is out of alignment
* When the window glass has been replaced
* When the door has been replaced
* When the window regulator has been replaced
Note: Prior to performing the relearn procedure the vehicle must have all 4 wheels properly inflated and mounted, the vehicle must be sitting on a level surface and all doors must be completely closed.
To relearn the window motor, follow these steps:
1. Ignition ON.
2. With a scan tool, select Module Diagnosis, Body Control Module, Configuration/Reset Functions and then select the appropriate Clear Window Learn Values for the window motor requiring the relearn procedure.
3. After the learn procedure, exit the scan tool learn procedure completely, the power window cannot be normalized and will not function until you exit the program.
4. Starting with the window completely UP, press and hold the power window switch until the window is fully open and continue holding the switch down for approximately 5 seconds after the window is completely open.
5. Pull the power window switch up until the window is fully closed and continue holding the switch up for approximately 5 seconds after the window is completely closed.
The window is now reprogrammed.
(thanks again to alldata for this information)
Hi my name is Travis and I have an addiction, an addiction to anything and everything dealing with v6 camaros. :wave:
****T.O.P. SNIPER****
PostPosted: Tue Feb 22, 2011 12:13 pm
Another good one that we hope to never use. Thanks again for starting this thread too.
Site Admin
PostPosted: Tue Feb 22, 2011 12:16 pm
yea, this one concerns me, as it talks about needing a scan tool to program it in the end. I looked into it and there is a bunch of things that need to be reprogrammed after installing which wasn't the case in the 4th gens. :( Crazy technology these days. lol
PostPosted: Tue Feb 22, 2011 12:25 pm
Fortunately for me I have a buddy that has the scan tool. He has helped me for the past 10 years scan codes. Good guy to have as a friend. Access too many things and connections if I should ever need help.
Site Admin
PostPosted: Tue Feb 22, 2011 12:29 pm
oh yea, we have the scan tools here at work too, but for the DIY it sucks to have to get things like that reprogrammed
PostPosted: Tue Feb 22, 2011 12:41 pm
Indeed it would suck. That is the problem with going forward with technology. We can go back to roll down windows and manual everything including brakes and steering too. ...... :umno:
Site Admin
PostPosted: Tue Feb 22, 2011 12:43 pm
yea, weight savings FTW :D
Laying rubber
PostPosted: Tue Feb 22, 2011 1:41 pm
I had to have my drivers window motor replaced already. Took her to the dealer to get it done,, they gave me a rental for 3 days while they waited on the part to come in. I was never so glad to get my car back!
Return to General Maintenance and Tech Issues
