System Part Diagrams
PostPosted: Tue Jul 16, 2013 11:45 am
Oil Filter Adapter
(440) Oil Filter Adapter
(441) Oil Filter Adapter Gasket
(442) Oil Filter Adapter Bolt
(443) Oil Filter Adapter Bolt – Long
(446) Oil Filter Bypass Valve
(447) Oil Filter Adapter Bolt – Large
(448) Oil Filter Adapter Bolt Sleeve
(449) Oil Filter
(450) Oil Filter Cap
(451) Oil Filter Cap O-ring
(456) Oil Filter Bypass Valve Body
(458) Drain Valve Assembly
(459) Drain Valve Assembly Seal
(728) Engine Oil Pressure Sensor
(729) Engine Oil Pressure Sensor O-ring
PostPosted: Tue Jul 16, 2013 11:46 am
Oil Pan Assembly
(1) Oil Pan Baffle Scraper Bolt
(2) Oil Pan Baffle Scraper
(3) Oil Pump Suction Pipe Bolt
(4) Oil Pump Suction Pipe Seal
(5) Oil Pump Suction Pipe
(6) Oil Pan
(7) Oil Pan Bolt – Long
(8) Oil Pan Bolt – Medium
(9) Oil Pan Bolt – Short
(10) Oil Pan Drain Plug Seal
(11) Oil Pan Drain Plug
PostPosted: Tue Jul 16, 2013 11:47 am
Oil Pump Second Design
(151) Lower Primary Timing Chain Guide
(154) Lower Primary Timing Chain Guide Bolt
(463) Oil Pump Housing
(464) Oil Pump Cover
(465) Oil Pump Driven Gear
(466) Oil Pump Drive Gear
(468) Oil Pump Cover Bolt
(470) Oil Pressure Relief Valve Bore Plug
(471) Oil Pressure Relief Valve Spring
(472) Oil Pressure Relief Valve
(474) Oil Pressure Relief Valve Bore Plug Retainer Clip
(475) Oil Pump Bolt
PostPosted: Tue Jul 16, 2013 11:48 am
Piston, Rings, Bearing and Connecting Rod
(200) Connecting Rod
(201) Connecting Rod Bolt
(202) Connecting Rod Bushing
(203) Connecting Rod Bearing
(210) Piston
(211) Piston Pin
(212) Piston Pin Retainer
(213) Piston Upper Compression Ring
(214) Piston Lower Compression Ring
(215) Piston Oil Control Rail Ring
(216) Piston Oil Control Ring Spacer
Users browsing this forum: No registered users and 3 guests
