System Part Diagrams
PostPosted: Tue Jul 16, 2013 11:26 am
System Part Diagrams for those trying to figure out what exactly a certain part is or where it goes while they are trying to work on their camaro.
Camshaft Cover Assembly
Camshaft Timing Components
Cylinder Head Assemblies
Engine Block Assembly
Engine Covers and Component Assemblies 1 of 2
Engine Covers and Component Assemblies 2 of 2
Engine Front Cover
Fuel Rail
Intake Manifold
Oil Filter Adapter
Oil Pan Assembly
Oil Pump Second Design
Piston, Rings, Bearing and Connecting Rods
PostPosted: Tue Jul 16, 2013 11:27 am
(250) Left Camshaft Cover
(251) Left Camshaft Cover Gasket
(252) Right Camshaft Cover
(253) Right Camshaft Cover Gasket
(254) Camshaft Cover Spark Plug Port Seal
(255) Camshaft Cover Bolt
(256) Camshaft Cover Bolt Insulator
(257) Ignition Coil Bolt Thread Insert
(258) Oil Fill Cap
(259) Oil Fill O-ring
(260) Left Camshaft Cover PCV Fitting
(261) Right Camshaft Cover PCV Fitting Orifice
(262) Oil Fill Tube
(263) Left Camshaft Cover PCV Fitting O-ring
(265) Left Camshaft Housing Cover Insulator
(266) Right Camshaft Housing Cover Insulator
(704) Ignition Coil
(704) Ignition Coil
(705) Ignition Coil Bolt
(719) Spark Plug
(719) Spark Plug
PostPosted: Tue Jul 16, 2013 11:34 am
(1) Primary Timing Chain Tensioner Bolt
(2) Left Secondary Timing Chain Shoe Bolt
(3) Right Secondary Timing Chain Tensioner
(4) Right Secondary Timing Chain Tensioner Gasket
(5) Right Secondary Timing Chain Shoe
(6) Secondary Timing Chain
(7) Camshaft Position Actuator Bolt
(8) Exhaust Camshaft Position Actuator
(9) Camshaft Position Actuator Thrust Washer
(10) Intake Camshaft Position Actuator
(11) Right Secondary Timing Chain Guide
(12) Left Camshaft Intermediate Drive Shaft Sprocket
(13) Camshaft Intermediate Drive Shaft Sprocket Bolt
(14) Left Secondary Timing Chain Shoe
(15) Left Secondary Timing Chain Tensioner Gasket
(16) Left Secondary Timing Chain Tensioner
(17) Left Secondary Timing Chain Guide
(18) Lower Primary Timing Chain Guide
(19) Lower Primary Timing Chain Guide Bolt
(20) Crankshaft Sprocket
(21) Primary Timing Chain
(22) Right Camshaft Intermediate Drive Shaft Sprocket
(23) Upper Primary Timing Chain Guide
(24) Primary Timing Chain Tensioner Gasket
(25) Primary Timing Chain Tensioner
PostPosted: Tue Jul 16, 2013 11:35 am
(300) Left Cylinder Head
(301) Right Cylinder Head
(302) Left Cylinder Head Gasket
(303) Right Cylinder Head Gasket
(310) Cylinder Head Bolt
(311) Cylinder Head Front Bolt
(313) Cylinder Head Coolant Hole Threaded Plug
(318) Spark Plug Sleeve
(319) Cylinder Head Oil Gallery Expansion Plug – 14 mm
(320) Exhaust Valve
(321) Intake Valve
(322) Valve Rocker Arm Assembly
(323) Hydraulic Valve Lash Adjuster Assembly
(324) Valve Stem Oil Seal
(325) Valve Spring
(326) Valve Spring Cap
(327) Valve Stem Key
(328) Cylinder Head Camshaft Front Thrust Bearing Cap
(329) Camshaft Oil Seal Ring
(330) Left Exhaust Camshaft
(331) Left Intake Camshaft
(332) Right Intake Camshaft
(333) Right Exhaust Camshaft
(336) Cylinder Head Camshaft Cap – Intermediate
(337) Cylinder Head Camshaft Cap Bolt
(339) Cylinder Head Oil Gallery Check Valve
(711) Engine Coolant Temperature Sensor
PostPosted: Tue Jul 16, 2013 11:36 am
(1) Crankshaft
(2) Crankshaft Key
(3) Crankshaft Lower Bearing
(4) Crankshaft Bearing Cap
(5) Crankshaft Bearing Cap Outboard Bolt
(6) Crankshaft Bearing Cap Inboard Bolt
(7) Crankshaft Bearing Thrust Cap
(8) Piston Oil Nozzle Bolt
(9) Piston Oil Nozzle
(10) Oil Pan Locating Pin
(11) Crankshaft Bearing Cap Side Bolt - Long
(12) Engine Block Oil Gallery Threaded Plug - 14 mm
(13) Crankshaft Rear Oil Seal Housing Assembly
(14) Crankshaft Rear Oil Seal Housing Assembly Bolt
(15) Transaxle Locating Pin
(16) Piston and Connecting Rod Assembly
(17) Engine Block Coolant Drain Threaded Plug - 14 mm
(18) Engine Block Core Coolant Expansion Plug - 34.3 mm
(19) Cylinder Head Locating Pin
(20) Engine Block
(21) Engine Block Oil Gallery Expansion Plug – 14
(22) Engine Front Cover Stud
(23) Engine Block Oil Gallery Threaded Plug - 20 mm
(24) Engine Block Oil Gallery Expansion Plug - 10 mm
(25) Crankshaft Bearing Cap Side Bolt - Short
(26) Crankshaft Upper Thrust Bearing #3
(27) Crankshaft Upper Bearing
PostPosted: Tue Jul 16, 2013 11:38 am
(1) Right Exhaust Manifold Heat Shield Bolt
(2) Right Exhaust Manifold Heat Shield
(3) Right Camshaft Cover Assembly
(4) Ignition Coil Bolt
(5) Ignition Coil
(6) Spark Plug
(7) Fuel Injector Sight Shield Cover
(8) Upper Intake Manifold Cover
(9) Intake Manifold Assembly
(10) Left Camshaft Cover Assembly
(11) Engine Flywheel Bolt
(12) Engine Flywheel
(13) Left Exhaust Manifold Upper Heat Shield
(14) Left Exhaust Manifold Lower Heat Shield
(15) Engine Assembly
(16) Left Exhaust Manifold Heat Shield Bolt
(17) Left Exhaust Manifold Heat Shield
(18) Cylinder Head Exhaust Manifold Bolt
(19) Left Exhaust Manifold
(20) Left Exhaust Manifold Gasket
(21) Oil Pan Assembly
(22) Crankshaft Balancer Bolt
(23) Crankshaft Balancer
(24) Engine Front Cover Assembly
(25) Exhaust Manifold Lower Heat Shield
(26) Exhaust Manifold Lower Heat Shield Bolt
(27) Right Exhaust Manifold Lower Heat Shield
(28) Right Exhaust Manifold Lower Heat Shield Retainers
(29) Right Exhaust Manifold
(30) Right Exhaust Manifold Gasket
PostPosted: Tue Jul 16, 2013 11:39 am
(1) Right Cylinder Head Gasket
(2) Right Cylinder Head Assembly
(3) Coolant Pipe Bracket Bolt – Small
(4) Coolant Pipe Clamp
(5) Coolant Pipe
(6) Water Inlet/Outlet Pipe Bolts
(7) Water Inlet/Outlet Pipe
(8) Water Inlet/Outlet Pipe Gaskets
(9) Water Inlet/Outlet Pipe O-ring
(10) Coolant Pipe Bracket Bolt – Large
(11) Coolant Pipe O-ring
(12) Engine Cooling Thermostat Housing Bolt
(13) Engine Cooling Thermostat Housing
(14) Engine Cooling Thermostat
(15) Engine Cooling Thermostat Seal
(16) Engine Cooling Thermostat Lower Housing Bolt
(17) Engine Cooling Thermostat Lower Housing
(18) Engine Cooling Thermostat Lower Housing Seal
(19) Engine Cooling Thermostat Gasket
(20) Left Cylinder Head Assembly
(21) Left Cylinder Head Gasket
(22) Oil Level Indicator Tube Bolt
(23) Oil Level Indicator
(24) Oil Level Indicator Handle O-ring
(25) Oil Level Indicator Tube O-ring
(26) Oil Level Indicator Tube
(27) Knock Sensor Bolt
(28) Knock Sensor
(29) Oil Filter Adapter Assembly
(30) Engine Short Block Assembly
(31) Oil Pump Assembly
(32) Timing Drive Assembly
(33) Water Outlet Bolt
(34) Water Outlet
(35) Water Outlet O-ring
(36) Water Outlet Seal
(37) Crankshaft Position Sensor Bolt
(38) Crankshaft Position Sensor
(39) Crankshaft Position Sensor O-ring
PostPosted: Tue Jul 16, 2013 11:40 am
Engine Front Cover
(1) Water Pump Pulley Bolt
(2) Water Pump Pulley
(3) Water Pump Assembly
(4) Water Pump Pulley Gasket
(5) Camshaft Position Actuator Solenoid Valve Seal
(6) Camshaft Position Sensor Bolt
(7) Camshaft Position Sensor
(8) Camshaft Position Sensor O-ring Seal
(9) Camshaft Position Actuator Solenoid Valve Bolt
(10) Camshaft Position Actuator Solenoid Valve
(11) Engine Front Cover Gasket
(12) Engine Front Cover Locating Pin
(13) Engine Front Cover
(14) Engine Front Cover Bolt
(15) Engine Front Cover Seal
(16) Crankshaft Balancer
(17) Crankshaft Balancer Bolt
(18) Engine Front Cover Bolt
(19) Water Pump Bolt
PostPosted: Tue Jul 16, 2013 11:42 am
Fuel Rail
(1) Fuel Pressure Sensor
(2) Fuel Rail Bolt
(3) Fuel Injector Retainer
(4) Fuel Injector O-ring Seal
(5) Fuel Injector Spacer
(6) Fuel Injector
(7) Fuel Injector Teflon Seal
(8) Fuel Injector Isolator Cup
(9) Fuel Injector Isolator Cup Retaining Ring
(10) Fuel Rail
PostPosted: Tue Jul 16, 2013 11:43 am
Intake Manifold
(282) PCV Hose Bolt
(282) PCV Hose Bolt
(283) Dirty PCV Hose
(285) PCV Hose O-ring Outer/Larger
(286) PCV Hose O-ring Inner/Smaller
(290) PCV Hose Right Bracket
(291) PCV Hose Left Bracket
(292) PCV Hose Clip
(503) Upper Intake Manifold
(509) Upper Intake Manifold Bolt – Long
(510) Upper Intake Manifold Bolt – Short
(514) Intake Manifold Brace
(515) Intake Manifold Brace Small Bolt
(516) Intake Manifold Brace Large Bolt
(524) Intake Manifold Cover
(525) Intake Manifold Cover Gasket
(526) Intake Manifold Cover Lower Gasket
(527) Intake Manifold Cover Bolt
(532) Fuel Rail Bolt
(560) Fuel Rail
(561) Fuel Injector
(562) Fuel Injector Retainer
(563) Fuel Injector O-ring Seal
(564) Fuel Injector Teflon Seal
(565) Fuel Pressure Sensor
(566) Fuel Injector Spacer
(567) Fuel Injector Isolator Cup
(568) Fuel Injector Isolator Cup Retaining Ring
(594) Fuel Injector Sight Shield Cover Ball Stud
(700) Fuel Injector Wiring Harness
(701) Throttle Body
(702) Throttle Body Bolt
(703) Throttle Body Gasket
(744) EVAP Purge Solenoid
(746) EVAP Purge Solenoid Bolt
(747) EVAP Purge Solenoid Tube
(752) EVAP Purge Solenoid Bracket
(755) Intake Manifold Tuning Valve
(756) Intake Manifold Tuning Valve O-ring
(757) Intake Manifold Tuning Valve Bolt
(765) Fuel Injector Wiring Harness Bracket
(766) Fuel Injector Wiring Harness Bracket Bolt
(776) BARO Sensor Bolt
(777) BARO Sensor
(778) BARO Sensor O-ring
