2010 Camaro V6 Fuse Block Diagrams
Alarms, Electrical Diagrams, HUD Displays, Hard-Wiring, Radar Detectors, LEDs
Moderator: SDCamaro10
PostPosted: Mon Mar 14, 2011 10:16 am
ENGINE COMPARTMENT FUSE BLOCK
To remove the hinged fuse block cover, press the clip at the front of the cover, and swing it up.
Notice: Spilling liquid on any electrical components on the vehicle may damage it. Always keep the covers on any electrical component.
J-Case Fuses Usage
Fuse 6 Wiper
Fuse 12 Starter
Fuse 22 Brake Vacuum Pump
Fuse 25 Power Windows Rear
Fuse 26 Power Windows Front
Fuse 27 Rear Defog
Fuse 41 Cooling Fan High
Fuse 42 Front Heater, Ventilation and Air Conditioning
Fuse 43 Antilock Brake System Pump
Fuse 44 Cooling Fan Low
Mini Fuses Usage
Fuse 1 Air Conditioning Compressor Clutch
Fuse 2 Transmission Control Module
Fuse 5 Engine Control Module Main
Fuse 7 Pre-Catalytic Converter Oxygen Sensor
Fuse 8 Post-Catalytic Converter Oxygen Sensor
Fuse 9 Fuel Injectors - Even
Fuse 10 Fuel Injectors - Odd
Fuse 11 Cooling Fan Relay
Fuse 14 Manifold Air Flow/Chassis Control
Fuse 15 Ignition
Fuse 16 Run/Crank IP
Fuse 17 Sensing Diagnostic Module/Ignition
Fuse 18 Run/Crank Body
Fuse 19 Transmission Control Module/Ignition
Fuse 20 Engine Control Module/Ignition
Fuse 31 Outside Rear View Mirror
Fuse 32 Canister Vent Solenoid
Fuse 33 Body Control Module #6
Fuse 34 Sunroof
Fuse 35 Front Heated Seats
Fuse 38 Washer Pump Front
Fuse 40 Antilock Brake System Valves
Fuse 46 HID Headlamp - Left Front
Fuse 47 HID Headlamp - Right Front
Fuse 50 Fog Lamps
Fuse 51 Horn
Fuse 52 Spare
Fuse 55 High Beam Headlamp - Right Front
Fuse 56 High Beam Headlamp -Left Front
Fuse 61 Heated Mirror
Mini Relays Usage
Relay K26 Powertrain
Relay K50 Run / Crank
Relay K55 Rear Defog
Relay K612 Cooling Fan High
Relay K614 Cooling Fan Control
Micro Relays Usage
Relay K61 Starter
Relay K69 Wiper Control
Relay K613 Cooling Fan Low
Relay K617 Air Conditioning Compressor Clutch
Relay K619 Wiper Speed
Relay K627 High Intensity Discharge Headlamps
Relay K632 Brake Vacuum Pump
"Compliments of Alldata"
PostPosted: Mon Mar 14, 2011 10:17 am
INSTRUMENT PANEL FUSE BLOCK
The instrument panel fuse block is located on the end of the instrument panel, on the driver side of the vehicle. To access the fuses, open the fuse panel door by pulling out.
To reinstall the door, push the door back into its original location.
Fuses Usage
F1 Discrete Logic Ignition Switch
F2 Diagnostic Link Connector
F3 Airbag
F4 Cluster
F5 Heating Ventilation Air Conditioning Controller
F6 Body Control Module
F8 Battery
F9 Spare
F10 Spare
F11 Not Used
F12 Spare
F13 Display
F14 OnStar® Universal Hands Free Phone
F15 Body Control Module 3
F16 Body Control Module 4
F17 Power Outlet 1
F18 Power Outlet 2
F19 Steering Wheel Controls Backlight
F20 Spare
F21 Spare
F22 Not Used
F23 Trunk
F24 Automatic Occupant Sensing
F25 Body Control Module 1
F27 Body Control Module 8
F28 Spare
F29 Body Control Module 5
F30 Body Control Module 7
Circuit Breakers Usage
CB7 Passenger Seat
CB26 Driver Seat
Relays Usage
K10 Retained Accessory Power
K605 Not Used
K609 Trunk
REAR COMPARTMENT FUSE BLOCK
The rear compartment fuse block is located on the right side of the trunk behind a cover. Remove the six convenience net retainers, the rear sill plate, and the two passenger side trim retainers, then swing the trim out of the way.
Fuses Usage
F1 Universal Garage Door Opener/Ultra-sonic Reverse Parking Aid
F2 Amplifier
F3 Radio
F4 Spare
F5 Convertible Top 1
F6 Convertible Top 2
F7 Spare
F8 Spare
F9 Spare
F10 Spare
F11 Spare
F12 Spare
F13 Engine Control Module/Battery
F14 Regulated Voltage Control
F15 Fuel System Control Module
F16 Spare
PostPosted: Mon Mar 14, 2011 10:35 am
Another great thread.........Thanks Travis.
PostPosted: Mon Mar 14, 2011 10:38 am
yea this was for bee sting, although it looks like that issue was figured out. :) Anyways in case others need it, here the diagrams are ;)
PostPosted: Mon Mar 14, 2011 6:58 pm
More great info.Thanks
Red Ryder 2011 2LT/ RS/ VR / Roto-Fab Cai / ARK DTS cat back exhaust / Defender Works Chrome door sills /RPI Stealth mud guards / DIY painted engine cover, and brake rotors / Suntek Window tint / RX catch can / Team LLT Badges. TEAM LLT
PostPosted: Mon Mar 14, 2011 7:23 pm
travis wrote:yea this was for bee sting, although it looks like that issue was figured out. :) Anyways in case others need it, here the diagrams are ;)
Man those are some nice looking diagrams ! Did you have to pay to join ALLDATA ? Anyway i did figure it out but this would have made it so much easier ! Well here are a few pics of the materials i used and i'll post the led's in the other mod section . Thanks again
TEAM LLT
PostPosted: Mon Mar 14, 2011 8:37 pm
yea our shop pays for it monthly.
Return to Wiring & Electronics
