Automatic DRL Relay Harness
Alarms, Electrical Diagrams, HUD Displays, Hard-Wiring, Radar Detectors, LEDs
Moderator: SDCamaro10
Just having fun
PostPosted: Sun Oct 26, 2014 5:29 pm
I found this module available from ijdmtoy.com that can be used to automatically turn on an led lighting circuit. I believe it uses a pizo crystal to turn on a relay based off of vibration detected. They say it can be used to wire up any 5w led bulb.
I added a ZL1 front end this year and still needed to power up the lower fog/ drls. This is a very simple connection to battery positive and ground, then plug in the lights.
I had to lengthen the wires, add a fuse and then install the conduit. The positive is connected to the under hood fuse block and ground to radiator mounting bolt. The wiring to the lights routed and then plugged in. The module was attached to the catch can bracket with tie straps. My first choice didn't vibrate enough to keep it turned on.
Since I wired it to battery positive it will turn on the lower drl any time engine vibration is felt and turns off 20 sec after engine stops.
2011 1LT early convertible, Victory Red, black bowties, engine cover, K&N, Elite catch can, Boston Acoustics sound, ZL1 front end, side skirts, rear diffuser and wheels, ECF Trucarbon heat extractor, alloy-tec emblems, NPP exhaust, Hurst shifter
PostPosted: Mon Oct 27, 2014 5:06 am
Thanks for posting this up. Interesting way to light those lights up.
Return to Wiring & Electronics
