How to Replace the Speakers for a 2010 camaro
Headunits, Speakers, Amps, TV/Screens, Subwoofers
Moderator: SDCamaro10
Site Admin
PostPosted: Wed Feb 23, 2011 9:47 am
Looking to replace a blown speaker or need to remove your speakers for an upgrade or other issue? Here are some pictures and directions to help you with this task
Front Center Speaker Replacement
Front Side Door Upper Speaker Grille Replacement
Front Side Door Speaker Replacement
Rear Speaker Replacement
Hi my name is Travis and I have an addiction, an addiction to anything and everything dealing with v6 camaros. :wave:
****T.O.P. SNIPER****
Site Admin
Removal
1. Remove Speaker grille
2. Remove the 2 screws holding the speaker in place
3. Lift speaker and disconnect electrical connection
Installation
Reverse removal instructions. Speaker bolts should be tightened to 2.5 Nm or 22 lb in
Site Admin
Removal
1. Using a plastic trim tool, release 3 plastic retainers and pull grille assembly straight up.
2. Remove speaker grille bolt (when re-installing, tighten to 2Nm or 18 lb in).
3. Disconnect electrical connector
4. Seperate the speaker grille halves
5. Unclip speaker from grille
Site Admin
1. Remove door trim panel.
2. Remove Speaker screw (when re-installing, screw should be tightened to 2.5Nm or 22 lb in.
3. Remove Speaker and disconnect electrical connector.
Site Admin
1. Remove the rear window shelf panel
- Disable SIR system
- Remove quarter upper trim panel
- Remove rear seat cushion
- Pull the release strap located in the center of the rear seat back cushion, folding the rear seat forward.
2. Remove speaker bolt/screw (one per speaker, re-install at 2.5Nm or 22 lb in)
3. Lift speaker and disconnect electrical connector
PostPosted: Wed Feb 23, 2011 10:16 am
Actually just disconnect the front speaker.
viewtopic.php?f=20&t=84
Site Admin
PostPosted: Wed Feb 23, 2011 10:22 am
yea yea yea, lol
Running 11s
PostPosted: Wed Feb 23, 2011 1:54 pm
may come in handy. thanks
MRT V1/ Injen CAI/ VMax TB/ RX Catch Can/ TrifectaImage
PostPosted: Fri Jul 28, 2017 10:35 pm
I noticed this left out the fact that you need to remove all the rear interior before you actually get to removing the rear deck. I just made a video on this. Trying to share it to help my fellow camaro owners out!
https://youtu.be/zr2WhxJjMFk
Return to Car Audio & Video
