Looking to replace a blown speaker or need to remove your speakers for an upgrade or other issue? Here are some pictures and directions to help you with this task
Front Center Speaker Replacement
Front Side Door Upper Speaker Grille Replacement
Front Side Door Speaker Replacement
Rear Speaker Replacement
How to Replace the Speakers for a 2010 camaro
Moderator: SDCamaro10
• Page 1 of 1
Hi my name is Travis and I have an addiction, an addiction to anything and everything dealing with v6 camaros.
![]() ****T.O.P. SNIPER**** http://www.michiganvisalus.com |
![]() ![]() Removal 1. Remove Speaker grille 2. Remove the 2 screws holding the speaker in place 3. Lift speaker and disconnect electrical connection Installation Reverse removal instructions. Speaker bolts should be tightened to 2.5 Nm or 22 lb in Hi my name is Travis and I have an addiction, an addiction to anything and everything dealing with v6 camaros.
![]() Removal 1. Using a plastic trim tool, release 3 plastic retainers and pull grille assembly straight up. 2. Remove speaker grille bolt (when re-installing, tighten to 2Nm or 18 lb in). 3. Disconnect electrical connector 4. Seperate the speaker grille halves 5. Unclip speaker from grille Hi my name is Travis and I have an addiction, an addiction to anything and everything dealing with v6 camaros.
![]() ![]() 1. Remove door trim panel. 2. Remove Speaker screw (when re-installing, screw should be tightened to 2.5Nm or 22 lb in. 3. Remove Speaker and disconnect electrical connector. Hi my name is Travis and I have an addiction, an addiction to anything and everything dealing with v6 camaros.
![]() ![]() 1. Remove the rear window shelf panel - Disable SIR system - Remove quarter upper trim panel - Remove rear seat cushion - Pull the release strap located in the center of the rear seat back cushion, folding the rear seat forward. 2. Remove speaker bolt/screw (one per speaker, re-install at 2.5Nm or 22 lb in) 3. Lift speaker and disconnect electrical connector Hi my name is Travis and I have an addiction, an addiction to anything and everything dealing with v6 camaros.
![]() for my build check here...viewtopic.php?f=28&t=57 ..........................................................TEAM LLT |
yea yea yea, lol
may come in handy. thanks
MRT V1/ Injen CAI/ VMax RX TB/ RX Catch Can/ Trifecta
• Page 1 of 1
