5th gen Camaro V6 Nitrous user list
Nitrous Oxide Systems, Wet, Dry, Direct Port
PostPosted: Mon Mar 21, 2011 10:51 pm
PostPosted: Mon Mar 21, 2011 10:52 pm
i will get some better pictures later
PostPosted: Mon Mar 21, 2011 10:53 pm
PostPosted: Tue Mar 22, 2011 1:24 am
OHIO-SPEED wrote:i'm running the zex blackout kit. only ran a 55 shot because it's running to lean! need to get into the computer.
just noticed were your fogger is, any reason for putting it there? i was always told that the fogger needed to spray straight at the tb or you could get a nitrous puddle and.....................BOOM!
PostPosted: Tue Mar 22, 2011 7:01 am
you would be correct if it was a larger system or a dry kit
ohio-speed.com is your #1 place for high performance parts & show car accessories
PostPosted: Tue Mar 22, 2011 8:17 am
OHIO-SPEED wrote:you would be correct if it was a larger system or a dry kit
a dry kit wouldn't have fuel puddling. A wet kit introduces fuel to the intake.
wet kits should be after the MAF and dry kit before the MAF. Bends will make the nitrous direction change so you will have to play with nozzle rotation so that the nitrous hits the MAF correctly and the MAF adjusts the fuel for the extra air it sees.
Wet kits are after so you don't have the MAF adding more fuel to the mix on top of your fuel jet and running to rich. Also you don't really want fuel going over your MAF wires, should be just air flowing over those things.
PostPosted: Sat Apr 02, 2011 2:40 am
I'm trying my hardest to get nitrous installed before the fest. Will keep you guys updated, and I'll take pics. It'll happen. Just don't know if it's before or after the fest.
Injen CAI, BBK Long Tube headers, Corsa Catback exhaust, Hurst short shifter, Eibach lowering springs, BMR Trailing Arms and Bushings, RX Catch can and Breather...
PostPosted: Tue Apr 05, 2011 6:38 pm
Now I've got to take pics.
Maybe this weekend after the car gets cleaned.
NX kit with their TPS and an MSD window switch.
America is all about speed. Hot, nasty, badass speed. -Eleanor Roosevelt, 1936
Tuned by Vince@Trifecta
PostPosted: Wed Apr 06, 2011 1:59 am
Getting zex installed next Tuesday. Just in time for the fest. :D
PostPosted: Wed Apr 06, 2011 8:19 am
poormanscamaro wrote:Getting zex installed next Tuesday. Just in time for the fest. :D
:woot: can't wait to see install pics!
Return to Nitrous
